Run Time: 0.000524
Run Time: 0.000162
WHERE (`xf_thread`.`thread_id` = '24755')
Run Time: 0.000556
WHERE (`xf_post`.`thread_id` = 24755) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.000633
SELECT `xf_attachment`.*, `xf_attachment_data_Data_1`.*
FROM `xf_attachment`
LEFT JOIN `xf_attachment_data` AS `xf_attachment_data_Data_1` ON (`xf_attachment_data_Data_1`.`data_id` = `xf_attachment`.`data_id`)
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (26743))
ORDER BY `xf_attachment`.`attach_date` ASC
Run Time: 0.000274
SIMPLE | xf_attachment | ref | content_type_id_date | content_type_id_date | 31 | const,const | 1 | Using index condition |
SIMPLE | xf_attachment_data_Data_1 | eq_ref | PRIMARY | PRIMARY | 4 | oilgasvn_db.xf_attachment.data_id | 1 | |
- XF\Mvc\Entity\Finder->fetch() in src/XF/Repository/Attachment.php at line 241
- XF\Repository\Attachment->addAttachmentsToContent() in src/XF/ControllerPlugin/Thread.php at line 46
- XF\ControllerPlugin\Thread->fetchExtraContentForPostsFullView() in src/XF/Pub/Controller/Thread.php at line 110
Params: 24755
Run Time: 0.000056
Params: 0, �x�
Run Time: 0.000082
Params: �x�, XF\Pub\Controller\Thread, Index, valid, thread_id=24755, 1715689479, , 0, �x�
Run Time: 0.000057
Run Time: 0.001601
Run Time: 0.000432
WHERE (`xf_session_activity`.`user_id` = 8043) AND (`xf_session_activity`.`unique_key` = '8043')
Run Time: 0.000117
WHERE (`xf_thread`.`thread_id` <> 24755) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`node_id` = 7) AND ((`xf_thread`.`title` LIKE '%Máy%') OR (`xf_thread`.`title` LIKE '%bơm%') OR (`xf_thread`.`title` LIKE '%nhiệt%') OR (`xf_thread`.`title` LIKE '%bình%') OR (`xf_thread`.`title` LIKE '%tích%') OR (`xf_thread`.`title` LIKE '%hợp%') OR (`xf_thread`.`title` LIKE '%Megasun%') OR (`xf_thread`.`title` LIKE '%MGS1.0%') OR (`xf_thread`.`title` LIKE '%-%') OR (`xf_thread`.`title` LIKE '%80%'))
Run Time: 0.000577
SIMPLE | xf_thread | ref | PRIMARY,node_id_last_post_date,node_id_sticky_state_last_post,node_id_sticky_state_vote_score | node_id_last_post_date | 4 | const | 18 | Using index condition; Using where; Using filesort |
Run Time: 0.000212
Run Time: 0.000601
Run Time: 0.001776
bytes_sent | 18011 |
bytes_received | 480010 |
packets_sent | 172 |
packets_received | 2096 |
protocol_overhead_in | 8384 |
protocol_overhead_out | 688 |
bytes_received_rset_header_packet | 405 |
bytes_received_rset_row_packet | 174 |
bytes_received_prepare_response_packet | 159535 |
bytes_received_change_user_packet | 319221 |
packets_sent_command | 85 |
packets_received_rset_header | 45 |
packets_received_rset_row | 30 |
packets_received_prepare_response | 1832 |
packets_received_change_user | 159 |
result_set_queries | 26 |
ps_buffered_sets | 26 |
ps_prepared_once_executed | 27 |
rows_fetched_from_server_ps | 133 |
rows_buffered_from_client_ps | 133 |
implicit_free_result | 25 |
proto_binary_fetched_bit | 777 |
proto_binary_fetched_short | 1337 |
proto_binary_fetched_bigint | 3602 |
proto_binary_fetched_decimal | 72 |
proto_binary_fetched_date | 35 |
proto_binary_fetched_json | 1920 |
proto_binary_fetched_blob | 801 |
com_stmt_prepare | 28 |
com_stmt_execute | 28 |
com_stmt_close | 27 |
bytes_received_real_data_ps | 314267 |
