Susi
Minimum Competencies:
• Work under direction of 2nd Engineer and reporting directly to the 2nd Engineer.
• The 3rd Engineer’s duty and responsibility is to maintain and ensure maintenance of below machinery in engine room assigned to him including, but are not limited:
- LP Boilers
- LP Boiler Feed Water Pump,
- LP steam piping system associated equipment.
- PSV of instrument air system, PSVs on steam system in Engine room.
- Inert Gas Generation System in Engine room: IG scrubber tower, IG blower associated IG valves,
- Distil Water Maker
- Drain Tank Condensate Pump and Main condensate pump
- Main Circulation Pump
- MGO Fuel oil system for Boiler
- All the relevant system
• Immediately report to 2nd Engineer for anything abnormal of machinery and equipment under his responsibility.
• To prepare P.T.W and submit to Utility Supervisor for approval at least 04 hours prior commencement of afternoon daily meeting.
• To carry out PLMs and CRM and inform to 2nd Engineer for requirements of maintenance and repair.
• To carry out maintenance and repair work as directed by 2nd Engineer.
To monitor spare part stocks (inventory, raise PR) of machinery/ equipment under his control are well inventoried and updated all time.
To support day-shift / night-shift operation together with Lead Utility Operator when required.
CV application via email: susi9.2017@gmail.com
Deadline: 31 Aug.2017
Thank you very much in advance for your interest in our company and CV application. We'll contact to you for the interview if your CV meet the requirement.
- Marine Engineering with Tanker Class 2 Endorsement, Inert Gas, COW and MED 3
- Minimum of 2 years’ experience as 3rd Engineer on Tanker or motor vessel.
- Steam Ticket
- Extensive experience required in maintenance of Boilers and other FPSO Utility Equipment
- Computer literate.
- Have experience of working using Permit to Work systems
- Proficient in English both written and oral.
- Effective communication skills
- LP Boilers
