PVT OFS - Lead Mechanical Engineer
PVTRANS OFS
PVTrans OilField Services is a professional provider of maritime transportation and services to the oil and gas industry in Viet Nam and abroad (FSO/FPSO, O&M...). We are now looking for driven, independent and enthusiastic Lead Mechanical Engineers as below:
· Detailed knowledge of mechanical maintenance practices applicable to offshore oil and gas asset.
· Associated technical standards and relevant legislation.
· Established supervisory and leadership experience of maintenance scheduling, organizing, coordinating and controlling of work including the management of contractors and vendors.
· Equipment is safely and effectively maintained in accordance with CPP expectations, Regulatory and other relevant codes and standards.
· To supervise other team members in the safe and efficient operation of the CPP and wellhead platform.
Reports to the Maintenance Supervisor, accountabilities include:
· Able to carry out planned mechanical maintenance in accordance with the requirements of the planned maintenance system.
· Experienced in undertaking fault finding, installation, isolation and re-instatement on mechanical systems and equipment – both rotating and static.
· Communication skills and the ability to present complex technical issues in a clear and concise manner.
· Manage risk in an effective manner. Be action orientated, results driven and able to inspire others.
· Extensive knowledge in diesel generators, turbines, hydraulics, and compression trains, rotating equipment and cranes.
· Supervisors to Minimize equipment down time.
· Ensure underlying causes of failures are understood and appropriate action taken to avoid repeat failures.
· Ensure mechanical maintenance work is scheduled and prioritized in line with maintenance work.
· Management processes, including the raising of relevant work permits.
· Highlight defects in practices, procedures, equipment and tools to the attention of relevant staff.
· Monitor and maintain environmental control measures.
· Emergency response role (see station bill).
- Carry out Emergency Response role as per station Bill.
- Demonstrate competence during Emergency Response Drills and training exercises.
· Training & competency.
- Achieve the desired competency level as described in the CASYs Job Competency Profile, mentor and assess others within your sphere of responsibility or as directed by the Maintenance Supervisor.
- Facility Specific Training Matrix - VN-05_1DEV-HCM-O-TA-016.
Minimum Competencies:
· Mechanical Technologist Certificate in Mechanics or equivalent.
· 5 years related experience in a marine or Topsides maintenance environment. (offshore oil and gas operations would be an asset) with 1-3 year experience in lead mechanical position.
· Working knowledge of regulatory and industry codes applicable to the maintenance disciplines.
· Working knowledge of marine and / or Topsides related mechanical equipment.
· Working knowledge of preventive and predictive maintenance, condition monitoring and with the application of computerized maintenance management systems.
· Familiarity with the theory and practice of rotating equipment and vibration analysis.
· Experience with the operation and maintenance of gas turbine driven generators, diesel engines, multi-stage centrifugal pumps and compressors, HVAC systems, hydraulic systems and associated auxiliary equipment.
· Ability to read relevant technical drawings and piping specifications.
· Effective communication skills (written, oral and computer).
· Leadership and teamwork skills / behaviours which support a team based organization.
· Proficient in English both written and verbal.
Salary: Competitive
Working location: Onshore - Vung Tau then moving to offshore work in Q2 2020
Application Deadline: 20 Sep 2018
Send your resume to pvtransofs-recruitment@pvtrans.com or contact us at +84 254 357 6669 - Ext: 211
