PVTrans OFS are now hiring Laboratory Technician to join Sao Vang Dai Nguyet project as follows:
Specific Accountabilities:
Application Deadline: 18th December 2020
- To conduct physical and chemical analysis on all plant samples, following standard methods using laboratory analytical equipment such as Gas Chromatograph (GC), Spectrophotometer, titrator, comparator, centrifuge and applying wet chemistry techniques when required.
- Has overall responsibility on the maintenance and safekeeping of all laboratory equipment installed, including glassware, chemical standards and reagents kept inside the laboratory unit.
- To replenish stock, including consumables, equipment, glassware and chemicals.
- Ensure safe use and secure storage of all hazardous substance used in relation to this function
- To ensure that all operations that are using hazardous substances are subject to Risk assessment under the requirements of the COSHH.
- To operate, maintain, calibrate all laboratory equipment, including but not limited to: GC; spectrophotometer; potentiometric titrator, pH, conductivity, particle counter, microbial counter and dissolved oxygen meters.
- Conduct chemical analysis on process treatment chemicals to evaluate purity with the available resources.
- Where applicable, performs sampling and field tests safely and without assistance in the process or utility systems, when so required.
- Prepare and standardize chemical reagents and solutions required for the testing of samples as per standard test methods.
- Move and fix carrier gas cylinders for GC and other instrumental analysis.
- To maintain proper housekeeping and ensure all required safety equipment and materials are available in the laboratory at any given time.
- Track and order consumables, equipment, glassware and all utility and production chemicals as required, to maintain the unit operational.
- Custodian of the lab report and ensures daily reporting figure accuracy across all tabs.
- Bachelor degree or above with major in chemistry or chemical analysis.
- 3 - 5 years experience in a laboratory from a petroleum refinery / petrochemical / oil and gas separation plants.Previous work in the offshore oil and gas will be an advantage.
- Working knowledge of oil and gas separation plants, understanding and exposure to process operation, would be preferred.
- Must be competent in isolations for high pressure gas samples.
- Sound understanding and knowledge of ASTM Laboratory Testing Standards for the oil and gas equivalent.
- Familiar with the application of computerized maintenance management systems.
- Proficient in English both written and verbal.
