Spencer Ogden | Instrumentation & Control Technician
Spencer Ogden
Good morning folks!
Spencer Ogden Oil & Gas is urgently looking for several Instrumentation & Control technicians to work for a refinery project located in the North of Vietnam. This is a 6-month contract (may get extended based on actual performance at site). Kindly find some of the requirements below:
  • Min. 4 years of experience in the Oil & Gas or Power Generation industry
  • Familiar with the installation work of Instrumentation & Control equipment / device / system
  • Construction stage experience
  • Commissioning stage experience will be an advantage
The main scope of work for this position will be carrying out I&C equipment / device installation activities at site. The technician will work together with the specialists to make sure that all I&C equipment / device will be set up correctly. Hence, construction stage experience is required.
If you are interested in this opportunity, or know someone, please send your up-to-date CV, in Microsoft Word format, to thomas.truong@spencer-ogden.com. The subject of the email should be: "Application for the I&C technician job.".
Shortlisted candidates will be contacted for a confidential discussion. Thank you!
file.ashx
