URGENT! PVTRANS OFS IS LOOKING FOR 4TH ENGINEER
PVTRANS OFS
PVTrans OilField Services is a professional provider of maritime transportation and services to the oil and gas industry in Viet Nam and abroad (FSO/FPSO, O&M...). We are now looking for 4th Engineer to join our team.
The successful candidates will be required to undertake the required job duties.
Minimum Competencies:
  • Marine Engineering with Tanker Class 2 Endorsement, Inert Gas, COW and MED 3
  • Minimum of 2 year experience as 4th Engineer on Tanker or motor vessel
  • Steam Ticket
  • Extensive experience required in maintenance of Boilers and other FPSO Utility Equipment
  • Computer literate.
  • Have experience of working using Permit to Work systems.
  • Proficient in English both written and oral.
  • Effective communication skills.
Specific Accountabilities:
  • Work under direction of 2nd Engineer and reporting directly to the 2nd Engineer
  • The 4th Engineer’s duty and responsibility is to maintain and ensure maintenance of machinery in engine room assigned to him including, but are not limit:
    • Sea water Booster pumps for WIP.
    • SWL Pumps
    • Sea water cooling pump of STG 9.2 MW,
    • HV STG condensate pumps,
    • Fresh water cooling pumps,
    • Bilge and Ballast Pumps
    • Engine room bilge pumps
    • Sewage treatment plant system
    • Galley / Accommodation grey water drain system in Engine room
    • Lube oil tank and piping system,
    • Lube Oil Purifiers,
    • Bunkering MDO and FW system.
    • Portable water system
    • HP & LP Boiler chemical dosing system
  • All the relevant system
    • Immediately report to 2nd Engineer for anything abnormal of machinery and equipment under his responsibility.
    • To prepare P.T.W and submit to Utility Supervisor for approval at least 04 hours prior commencement of afternoon daily meeting.
    • To carry out PLMs and CRM as per 2nd Engineer for requirements of maintenance and repair.
    • To carry out routine maintenance and repair work as directed by 2nd Engineer.
    • To monitor (inventory, raise PR) spare part stocks of machinery /equipment under his control well inventoried and updated all time.
    • Maintain and update inventory of all Lube Oil & Grease, Freon.
    • Take distilled water and portable tank daily sounding.
    • To be incharge of MDO bunker tanks under Utility Supervisor’s instruction.
    • To support dayshift / nightshift operation together with LUO when required.
Salary: Competitive
Working location: OFFSHORE- FPSO - Vungtau, VietNam
Application Deadline: As soon as possible
Please email resume and any references to HR Department at:
pvtransofs-recruitment@pvtrans.com
