PVTrans OFS - Opening for Control Room Operator Post
PVTRANS OFS
Member
PVTrans OilField Services is a professional provider of maritime transportation and services to the oil and gas industry in Viet Nam and abroad (FSO/FPSO, O&M...). We are now looking for Control Room Operators to join our team.
The successful candidates will be required to undertake the required job duties.
Accountabilities in brief:
• Under guidance of the Operations Supervisor lead the operations team to deliver required gas and liquid volumes to meet daily/monthly and annual production targets.
• Operate the production facilities Sao Vang & Dai Nguyet in a safe and efficient manner in accordance with established parameters, procedures and regulations.
• Ensure well operating guidelines and known and followed.
• Responsible for communication between Sao Vang, Thien Ung & PVGas onshore for all routine and emergency matters.
• Report all incidents, near misses and hazardous conditions.
• Control for all field facility processing and utility systems.
• Ensure that product quality specifications are met.
• Monitor and control of process system, WHP manifold, subsea wells, flow lines, and risers according to established procedures.
• Track and monitor all personnel movement in restricted areas.
• Provide direction to Process Operators during normal, upset, and emergency conditions.
• Provide accurate production volume, quality, and metering data for production reporting and accounting.
• Document and report any environmental exceedance to Operations Supervisor.
• As a key member of Emergency Response Team ensure correct emergency procedures are known implemented and keep OIM up to date on plant conditions.
• Adhere to standing instructions all the times.
• Responsible for accurate daily production report, production loss reporting and maintain daily activities records.
• Manage the Permit to Work (PTW) system/process to ensure that PTW required works properly controlled, coordinated and communicated knowing and understanding work being undertaken on the facilities.
• Responsible to control and maintain fire & gas logs and overrides and inhibits registers and ensure all changes to plant instrumentation are logged and recorded accurately.
• Responsible for ensuring “Equipment out of Service” log/board is accurate
• Responsible to contact with standby/supply vessels within 500 meter zone
• Responsible for making clear and professional public address announcements. (Suggest a standard set of PA announcements).
Minimum Competencies:
• University degree, Major in Oil and Gas is preferred.
• 5 years related experience in the oil/petrochemical industry.
• Previous experience as a control room operator. (2 Years).
• Working knowledge of Distributed Control Systems and computerized control/safety systems.
• Working knowledge of separation, compression, utility systems.
• Thorough understanding of all production equipment and systems on the installation.
• Familiar with computerized maintenance management systems.
• Effective communication skills (written, oral and computer).
• Proficient in English both written and oral.
• Leadership and teamwork skills/behaviours which support team based organization.
• Ability to understand and react with diverse groups and operations
Salary: Competitive
Working location: Vung Tau
Application Deadline
: 25 Sep 2018
Please send your resume and any references to HR department at:
pvtransofs-recruitment@pvtrans.com
Đính kèm
    132.9 KB · Lượt xem: 31
Sửa lần cuối:
