Vina Offshore tuyển dụng Pressure Vessel Engineer
  • Position: Pressure Vessel Engineer
  • Reports to: Commercial Manager
  • Department: Commercial Department
Purpose (Clear & brief statement or summarise the overall role of your job from the organisation's point of view)
  • Be responsible for evaluating the client’s requirements and develop design data including strength calculations and drawings in accordance with the requirements.
Key accountabilities (Tasks required to achieve the job’s purpose?)
  • Evaluate the client’s requirements and develop design data including strength calculations and drawings in accordance with the requirements.
  • Review technical specifications and drawings to determine scope of work, coordinate the production effort and maintain a standard design process.
  • Prepare MTO and co-ordinate with procurement for the material supply.
  • Apply ASME CODE for designing and calculation.
  • Responsible for the coordination with Design, Material Control, Procurement and QA/QC on matters pertaining to the project.
  • Interface with other departments, clients, vendors, subcontractors and third parties as per Technical Manager’s instructions.
  • Perform technical tasks assigned by Technical Manager on onshore or offshore feasibility, conceptual, basic engineering, FEED, detailed design and EPC/EPCM projects.
  • Assist the Technical Manager in the verification of technical documents relevant to the responsible units.
  • Assist the Technical Manager to answer relevant site technical queries.
  • Prepare job specification for piping fabrication, inspection and testing (where Client specification are not available)
  • Participate in inter-disciplines, projects, clients and vendor meetings when requested by Manager.
  • Perform material and equipment inspection assigned QC Engineer; record the inspection in relevant format. Inspection of received consignment documents and related Purchase Order
  • Collect all necessary information on the materials/equipment to be received on site such as copy of P.O., packing lists, mill cert.
Job holder specifications (Knowledge, skills, experience and any other special requirements for the job holder)
  • Bachelor’s degree in Mechanical Engineering from an accredited University
  • 07 years of working experience as design engineer and supervisor related fields
  • Prepare and checking technical specification (Welding Procedure, Fabrication Procedure, Project Procedure, material selection, FAT Procedure, Coating and painting Procedure, gauging, clean and hydro testing) of subsea pipeline.
  • Piping supervisor for HUC and modification Badamyar Offshore Project (Total) at Myanmar
  • Installation, flushing, pressure test, commissioning of compressor air, system, CWS, CWR, Natural gas.
  • Commissioning and maintenance Utility system as cooling pumps, chiller package, blowers.
  • Installation, operation and commissioning of centrifugal pumps, centrifugal fan.
  • Supervisor and checking installation, aliment work of heavy equipment as drum dryer, granuator and chiller, boiler unit.
  • Must have the ability to calculate/design the pressure vessel manually as per ASME code in case of software failure
  • 04 years design static and rotating equipment as below:
  • Pressure Vessel apply ASME section VIII Division I.
  • API 610 Centrifugal Pump.
  • Rotary Pump as Gear pump, Screw pump.
  • Rotary Compressor .
  • EFM Hoist and Crane .
  • Fire Fighting Pump with UL, FM approval.
  • Centrifugal fan.
  • Project Coordination (coordinate all works/correspondence between Client- Contractor-Subcontractor/ vendor).
  • Coordinate & Purchase materials & service (Pipe & structural material, Certification & Other service….).
  • Project Cost control.
  • Preparation & finalization of Change Order/ Variation Order with Client and Sub-contractor/vendor.
  • Prepare and execute the proposal/quotation (Prepare technical documents and commercial submit to client).
  • Knowledge API standard as:
  • API 610 Centrifugal pump and General Refinery Service
  • API 616 Gas Turbine for Petroleum, chemical and Gas Industry Service
  • API 617 Centrifugal Compressors for General Refinery Service
  • API 618 Reciprocating Compressor for General Refinery Service
  • API 619 Rotary Type Positive Displacement Compressors for Petroleum, Petrochemical, and Natural Gas Industries
  • API 673 Centrifugal Fans for Petroleum, Chemical and Gas Industry services
  • API 676 Positive Displacement Pumps-Rotary
  • API 682 Shaft Sealing System for Centrifugal & Rotary Pump
  • Knowledge ASME standard as:
    • ASME Section VIII Division I &II: Pressure Vessel
    • ASME B16.5 Pipe Flange
    • ASME B16.11 Forged Fitting
    • ASME B31.3 Process Piping
    • Competent auto card 2D, PV Elite, excel, word, Microsoft project
Relationships (Inside and outside the organization which the incumbent will be required for interface)
  • Other department
  • All employees & cross-functions
  • Clients/Owners/ suppliers
Location (Where your tasks will be performed)
Road #5, Dong Xuyen Industrial Park, Rach Dua Ward, Vung Tau City. However, it is at the discretion of the Management to relocate you from time to time to other business locations within Vietnam.
Ứng viên gửi CV về địa chỉ email : service@vnoffshore.com.vn
