Honeywell UOP has announced that it will cooperate with PetroVietnam Gas Joint Stock Corporation (PV Gas) to build a modular gas processing plant with daily capacity of 7 million cu.m.
PV Gas will use the plant to separate liquefied petroleum gas (PLG) from natural gas at its processing plant in the southernmost province of Ca Mau.
Honeywell Process Solutions will also serve as a main integrated main automation contractor (I-MAC) and supply integrated controls and safety systems for PV Gas’s production plants and terminals.
Posco Engineering Co., Ltd and Petrovietnam Technical Services Corporation (PTSC) were selected as contractors for engineering, procurement, construction of the project.
The plant is scheduled to become operational by 2017.
Honeywell UOP is a global leading group in gas processing. It has helped its customers meet the demand for natural gas for more than 60 years. The firm’s gas processing solutions focus on contaminant removal and natural gas liquids recovery to help maximize the value of its customers’ gas streams.
Plant modules are assembled quickly, significantly reducing construction time and expense, and enhancing reliability after startup.
Source: VNA
